Good evening,
Im trying to find in Building regs a document relating to toughened glass.
Im converting a staircase from softwood to Oak. I'll be using a handrail and baserail that is pre-rebated for either 8mm or 10mm toughened glass.
The largest single piece of glass will be 1000mm long x 850mm high on the landing, whereas on the rake with a pitch of 41 degrees and horizontal span of 1509mm between the newel posts, there will be 2 sections of glass each having the long edge at 41 degrees measuring 901mm with a vertical height of 850mm.
Are there any tables that show the maximum tolerance size permitted for 8mm or 10mm toughened glass please? Or building regs docs.
