900mm shower tray
4 Apr 2010
Humberside
If a 900mm shower is wanted to be fitted in to a room to be built. What width would the room need to be 900mm from finish plaster to finish plaster?
It probably needs to be a similar size to that needed if using danish plaster (sorry - couldn't resist :sneaky:)
Mine is 907mm which give clearance to slide the base in.
Then tank and tile down onto the tray
Ideally you want the tray first as they are not always the exact size as in the brochure .
