NOT A DIG AT FLAMEPORT
Let's have a laugh coming up with daft/scary answers to the questions below...
Some testing scenarios for you - these are basic things and you should know the answers without looking them up in a book or elsewhere. (in some cases you won't find the answers in a book anyway)
1. You have installed a new radial circuit consisting of 3x socket outlets. The end of the cable is inside the consumer unit, but not connected to anything.
What are the tests you would do, in what order, and how are they done?
2. Customer has a lighting circuit with 4x pendant lights, the MCB has tripped and won't reset. How do you locate the fault?
3. Customer's house has a CU with 6 circuits (MCB for each), the main switch is a 30mA RCD. The RCD has tripped. The customer has tried to reset the RCD but it will not. Before using any test equipment or tools, what would be the first thing to do?
4. Before any testing is done on a socket outlet circuit in an occupied house, what is the first thing to do?
5. When measuring Zs for a lighting circuit protected by a 6A type B MCB, the results is 3.0 ohms. Is this acceptable?
6. Ring circuit with 10x socket outlets on it. Sockets 1-9 work correctly. When anything is plugged into the 10th socket, the RCD trips every time. What is the most likely cause of this fault?
7. When measuring Ze for an installation with a TNS supply, the result is 0.7 ohms. Is this acceptable?
8. A lighting circuit has several dimmer switches. How will this affect testing?
9. After using a ladder to install a new circuit and outside floodlight at roof level on a 2 storey house, what test would not be done? Why?
10. Radial circuit for a cooker. Cooker is not connected, it's a new house. When doing an insulation resistance test, the results are LE 200M, NE 200M, LN 0.25M. What is the most likely cause of this apparent fault? (the answer is not cable damage or trapped wires).
