a little disaster has struck
28 Jan 2009
Birmingham
hope someone can help
i was plastering under the stairs last night , when i was polishing the plaster a small amount of it just fell away when i tried to put some more plaster into the hole it just got bigger so i have left it to dry overnight.
i now have a small hole , it looks as if the plaster isn't even touching the boards underneath??? the boards under the plaster are a little bouncy. what do i fill the hole with that will give a good finish????
what if when i fill the hole the plaster just cracks and the hole gets bigger?????
confused as the rest of the plaster is sound..
thanks
Just use polyfilla or similar.
If the hole get bigger etc. then you are f**ked and will have to start again; this time properly preparing the background you are plastering.
