- Joined
- 5 Jul 2010
- Messages
- 171
- Reaction score
- 1
- Country
I need a new radiator in a room which has had the old one removed due to having work done in the room.
The window in the room is 1.8mm wide. Having used a number of rad sizing calculators on the internet they all come up with pretty much the same figure for the size of room I have (including all the additional info like floor types, window size etc etc).
My question is though, looking for a suitable single panel rad with the same Btu output they are all small in comparison to the window.
In other words having a radiator that matches the window width gives way too much heat output.
In order to the suggested heat output I would need a narrower rad of say 1200mm or 1400mm if its 500mm high.
What effect to the system would using an 1800mm rad have which had 1000 more Btu's output?
I guess this is a bad idea?
The only reason I looked for a rad that was the same width as the window is for aesthetic reasons.
