Accenta G3 panel unresponsive
30 Apr 2013
Cheshire
Accenta/ Optima G3
For no apparent reason my control panel has stopped working.
It is lit up in the usual way, but none of the buttons do anything...
Anyone?
tamper light lit ? press reset, optimas lock out keys when there is a tamper fault or had a power cut ? when was the battery last replaced ?
Your CP has locked out open panel disconnect battery and mains power repower to clear fault, give the battery a shake if it rattles its knacked
................... give the battery a shake if it rattles its knacked
So that's the way to test to see if a battery is, as you so eloquently put it, knacked, is it?
If it rattles it has been 'u s' for a long time.
Thanks Gasspark,
Come to think of it there was a short power cut recently (durrr).
Just a bit worried though, when i open the main panel and the alarm sounds, I won't be able to silence it because of the unresponsive buttons?
Thanks Gasspark,
The buttons will be responsive again open power up
