Hi
Just finished installing Accenta G4 Mini Alarm system. Completed Walk Test to test system integrity - all OK. Temporarily wired bell box indoors (main sounder temp replaced by 12v low intensity piezo sounder) to 'burn in system - too we/windy to install outdoors at moment!!
System Configuration:
Program 1 (only) is being used. Hallway PIR on Zone 2 (faces door and covers hallway) and Magnetic door sensor on Zone 1. Four other zones are being used. Zones 1 and 2 timed; 30 secs entry and exit time delays. Exit Mode: Timed. Remote Control panel is located in the Hallway.
Problem:
On setting the alarm Zone 1 setting fault displays on the LCD Remote Control Panel. Yes the PIR is actuated on entry but this does not trigger the Alarm. The house can be exitted via the door and the system will set. correctly. Entry via Zone 1 and 2 to the Remote Panel to disarm works correctly - over 30 secs the Alarm goes off.
So why is the Remote displaying setting faults when, apart from this system functions correctly? To supress annoying beeps from Remote Panel during setting I set the Exit Mode to Silent Time - but this is really masking 'the problem'.
Can anyone shed advice on this please. I dont find the User Guide particularly helpful.
Thanks in anticipation.
Problem:
