Act Lifestyle LP522
6 Mar 2011
London
When I press the 'SET' button I do not see the "CLOCK ?" option coming up.
Also the bottom part of the data on the screen is not visible.
Any suggestions please?
Can this unit be "reset"?
Thanks for your help
Zack
If it is new - take it back.
If not you could try disconnecting from the supply and remove the battery.
Try new battery.
The instruction say - switch off the power before removing from back-plate and refit before switching on the power
Other than that it sounds faulty.
They are not repairable.
From instructions -
5. If you get confused and wish to start the whole
programming procedure again, press the SET and +
buttons together for a moment. The programmer will
revert to a mid-night time display and the built-in
standard programme. You will now have to set the clock
again and then enter the programme you want.
6. When you are making adjustments to timings, if no
button is pressed for 1 to 2 minutes, the programmer will
automatically revert to the normal operating mode.
