Replacement of ACL Lifestyle LP 522 programmer
6 Mar 2011
London
My current programmer has lost some lines on the display and does not allow to reprogram it. Otherwise it is working fine according to the pre-existing settings.
Can anyone please guide if this is a matter of a battery change or the whole unit needs replacement.
Is the replacement with a new LP522 a straightforward DIY job without the need for rewiring ?
Thanks in Advance
Zack
Thank you Pete.
Would you know of any good step-by-step video showing how to replace the unit without removing the back plate?
Zack
You do not need to remove the backplate. Simply loosen the two screws underneath and pull the front off and fit the programmer to the EXISTING wall plate. The instructions with the new timer are simple to follow.
