Hello, my first post here, so please be gentle
I'm replacing an old wall light. The issue is that the old one has a pull cord switch in the fitting and the new one has to be controlled by an external switch. So I need to find a way of installing this switch.
I've looked at the reference here and it looks like I should wire in the new switch using a junction box - is this correct?
My other question: given that they have to be inspectable and can't be plastered over, is it simplest to run the cable between the switch and the fitting it is to control, from a junction box in the ceiling cavity (with the cables buried in the plaster)?
Thanks in advance.
Thanks in advance.
