I want to change the 4 spot light in my kitchen to 8 x 50 watt downlights.
The house only has one lighting circuit for most of the lights. There is a circuit for the converted garage lights and one for the door bell and outside light.
I don't want to overload the circuit, so intend to extend the garage or door bell circuit to the kitchen.
The garage circuit current runs 9 x 50 watts spots.
I thought the door bell circuit would be best. So is it OK to run a new 1.5mm cable through the loft and down into the kitchen lights and the other end connect into the fuse box onto the same 6amp fuse as the door bell circuit. Meaning two sets of wiring from the one fuse.
If this is OK, is it OK if I do the work myself. I read the post on part P etc. If I do it myself do I inform building regs (or whoever) of the work and they inspect.
Thanks for the prompt reply as I am on a deadline to get the ceiling plastered.
