Advice sought to fix so called self adhesive "foil" ( thin artificial veneer ) to sanded timber. Timber (deal) was previously varnished but has been sanded and cleaned to remove all varnish.
The adhesive backing to the foil holds for a short time and then releases.
Trials with warming the adhesive give similar failure.
Area is circa 1200mm by 650mm. Foil to be curved around the rounded edges by gently warming. The curving is sucessful ( other than failing to remain attached.
