Adjusting water level in the loft tank with PART2 ballvalve float
12 Jul 2011
Stirlingshire
We have now this new Part 2 ballcock float valve working properly in the water tank. But the water level in the tank seems too high almost reaching the overflow pipe in an inch.
The water in the tank is little used just for toilet flushing, hence there is no need for water to be that high in the tank stored.
How does it get adjusted? Now the float has been set at the lowest end point of the arm towards the bottom of the tank. The arm is very short in length (hence impossible to bend). It has a screw which can be open to raise the float, but then wouldn't it even up the level when the float is set raise in the arm more towards to the bent point?
