Advice for Ceiling Repair
30 Aug 2010
West Midlands
Hi All,
I hoping that someone will be able to give me some advice on how to repair a damaged section of our lounge ceiling. To cut a long story short about 8 months ago, SWMBO left the shower running upstairs water seeped down the side of the curtain through a gap between the bathroom floor and hall and down into the ceiling void. Over time the plasterboard has weakened to the point whereby I have had to remove the light fitting.
How easy for a DIY novice is it to repair the damage, I'm assuming that I'll have to cut away the damaged plasterboard to where it is sound and replace the plasterboard, alternatively as an estimate how much can I expect to pay if I get out a plaster?
Many thanks
Jon
Cut the hole, into a square/rectangle one.
Fit two slats of timber above hole, screwing them to the existing ceiling,
either side of hole, so the timber can the be used to fit to.
Cut the plasterboard to the correct size, make hole for cables, make sure circuit electrics are isolated before you start this work.
Then feed cables through hole, screw up plasterboard to timbers, be sure not to damage the cables when screwing the board up.
Remove about 50mm of the surface plaster finish around the edge of the hole, so exposing plasterboard beneath plaster, this will allow the joint tape to sit on the board and reduce any chance of the repair being uneven. This will be best done by cutting into it with a stanley knife.
Then joint tape the joints, then the area can be filled out and sanded down, using a joint compound such as easyfill or you can purchase smaller ready mixed quantitys at the DIY sheds and merchants.
The compound does shrink on drying, sand down after each application, using 120-150 grit paper. Three applications in total will do the job.
This will allow a nice smooth finish to de primed for decorating.
http://www.screwfix.com/prods/68520...e/Plasterboard-Joint-Tape-Scrim-48mm-x-90m?cm
http://www.british-gypsum.com/produ...ries/gyproc_accessories/gyproc_easi-fill.aspx
