Hi All
My mate has over tightened a 'slight' leak resultig in a crack/split at in the copper pipe at the compression area of the lockshield.
What size is the small microbore pipe ? 8 or 10mm ??
Can i get an compression isolation valve to fit the above ?
Can i purchase a short length of the pipe as i would only need a couple of inches to make right.
EDIT - also what do i use to cut the pipe ? I only hace Copex 15/22mm cutters.
