Microbore Pipe bender
Got an irwin one from bes for about 17=18 quid
spot on nice clean tight bents!
Ive also found out myself that some silverline stuff is sh1t
just ordered one thanks for that mate i looked on ebay and that one was about quid cheaper than on ebay
you could fill the pipe with water and freeze it..
that's how they bent the pipes on a trumpet... :)
the only time i use microbore for rads etc is using the harder table x stuff. it only comes in 3 meters like usual.but the end results are you get better runs and easier to bend, without the usual flatening.
I usually find that if you are using microbore, if you are careful, you can bend it as it is. Obviously bends can't be too tight, but if you keep moving the pipe as you bend, so that you're not bending in the same spot, its OK.
