I plan to lay 68msq of Overland Silver Porcelain 20mm and 900x450. Plan to use a brick bond effect when laying. I have prepared the sub base and got all my drainage sorted. My garden is on two levels with steps up to the top level.
Ive done quite a lot of research regarding porcelain laying but just want to make sure I've got everything covered. So far I have learned
1. Application of SBR primer to adhere to mortar
2. Cut with a continuous good quality diamond blade. Although I only have a 110 mm grinder, will this be adequate?
3. I plan to have 5mm grout lines so will need to be spot on with levels so any advice with regards to that appreciated.
4. Keep SBR off the face of the tile and clean off immediately.
Any other advice or pitfalls to avoid would be greatly appreciated
