- Joined
- 25 Jan 2004
- Messages
- 56
- Reaction score
- 0
- Country
Situation:
(a) satellite dish already up on side wall of house, feeding one room in house with Sky+
(b) new detached annex being built with a metre or two of that side wall of house. Annex is a small two-up two-down.
(c) would like to keep option open of having different Sky+ channels in the 4 rooms of annex, but for now probably only one or at most two different Sky+ channels will do.
(d) may look at adding another Sky+ room in house
My current thinking is:
(i) keep existing dish on house, with octo LNB. Install aerial next to it for standard signal.
(ii) feed five cables across to the annex, to a central point... four from the dish and one from the aerial.
(iii) from central point in annex, feed two cables to each room.
(iv) for now, at the central point just connect the 4 cables from the dish to two rooms (two per room), so only two rooms have Sky+ (direct feed from dish).
(v) at the central point, connect the cable from the aerial to all four rooms (over one of the two cables from central point to rooms), so all rooms have standard signal at least.
(vi) back at the dish, connect the other four outputs to two separate rooms in the main house.
This still gives the option of adding more rooms in the annex later without any additional cabling... by adding a multiswitch at the central point, using the four existing cables from the dish, feeding signals from the multiswitch to all four rooms using the existing internal cabling.
Not sure, but it may not be possible to run the multiswitch in the annex and still use the other four LNB output for the main house? If that is the case, worst case is that I put up another dish (and start to look like I'm an offshoot of GCHQ).
Does the above make sense? Or are there far better ways of doing this? Bottom line is I want maximum flexibility, and don't want to have to add any more cabling in the new annex in future through shortsightedness now. And I don't particularly want a dish up on the new annex.
Thanks.
Thanks.
