- Joined
- 9 Mar 2026
- Messages
- 33
- Reaction score
- 5
- Country
Hi there
I recently replaced my kitchen tap and turned off the water using the stop cock under the kitchen sink when doing so. There is a pressure gauge next to the stop cock and I believe it is next to a Pressure Relief Valve. Before I started the job it looks like the pressure reading is abot 4.5 but there is a red/orange needle pointing at 3.
I read that having the pressure too high can cause pipe banging which is something we experience regularly - mainly when the washing machine is on.
I therefore (with my lack of plumbing knowledge) thought I should reduce the pressure a bit to prevent this banging so I didn't completely open the stock cock (so I think). My hot tap in the utility room is coming out cloudy (air bubbles I believe as it clears in a glass from the bottom upwards). I am pretty sure this didn't happen prior to me replacing the main kitchen tap. I therefore am wondering if the settings for the stop cock is causing this. I did read that the stop cock should be fully opened. I tried turning it anticlockwise more to open it last night but it just keeps turning and it actually leaked a small pool of water out (about a couple of tablespoons max). I turned it clockwise again a bit for fear this could become more than an small pool. I left it all night and there was no additional water.
So I have a couple of questions. One is can I safely keep turning the stop cock tap handle anticlockwise and will it eventually stop. My fear was it would just pop off and I would get loads of water. I did read that it should have a hard stop at some point.
The other question relates to the red/orange needle pointing at 3 on the pressure gauge. I am assuming this is recommending a max of 3 bars. When I initially turned the stop cock back on after my tap replacement I only partially undid it and pressure was sitting around 3 but the water pressure for the cold water was very weak upstairs. Note I have a worcester greenline boiler and a hot tank in the airing cupboard upstairs (I believe it is gravity fed but could be wrong). There is no cold water or any tank in the attic.
So should I be turning the Pressure Relieve Valve at all. Note I have never touched this before but looks like you can turn the blue bit at the bottom.
Note the tap photo is the tap that is delivering the cloudy hot water. Also note the hot water in the downstairs toilet is not appearing cloudy. This is a different type of tap (a mixer tap)
Any advice much appreciated.
