good day folks ! i was advised to visit this form for my query as here may be more applicable to my region.
i just want to make sure i have this down right. so im wiring a room, 2 lights and an outlet. i have rough wiring in, pulled a 2.5 from the breaker box in the next room and run 1.5 to light fixtures and outlet and then everything leads back to the switch. i joined all the live (red) wires together (1 from supply and 3 from lights and outlet), insulate wrap it. the supply neutral i connect to one switch for a light and the neutral going to the lights to the other terminal. i then attach the neutral (black) wire leading to the outlet on the switch terminal that has the supply neutral. i then attach a piece of black wire to that same supply neutral terminal on the 1st switch and feed it over to the second near by switch and then to the other terminal connect the neutral for the second set of lights.
is that okay ? i tried the first set of lights and they worked, but just wanted to make sure.
