Air in bathroom radiator why??
21 Nov 2010
Liverpool
why does air always seem to gather in the bathroom radiator, its as if the air knows its the bathroom happens in mine an my sons! and my mums!!
advice welcome
alex
It may well be the 1st rad on the circuit and as such the air collects in that rad first.Is it air? Do you hear air/bubbling noises when the system is running?
If you are having problems understanding a simple reply what do you want other than a solution to your problem.Don't reply with just a smilie. :o
back to the subject boys
is your bathroom radiator on a towel rail circuit-(does it get hot in summer) if it is its like gas man said, its one of the 1st tees after pump-you could always try turning pump down 1 setting(because it might be drawing air via open vent pipe from the expansion tank-or you could raise the open vent pipe over expansion tank
