Airlocked CH system
  • Thread starter Thread starter OJ
  • Start date Start date
OJ
10 Nov 2007
Hampshire
I drained down my central heating system to replace a 3-way valve....and now my system seems airlocked - loads of loud clunking sounds, etc.
I am only getting heat in 1 upstairs rad and no downstairs rads. The header tank has very dirty (hot) water in it, and the expansion pipe is spluttering into it every now and again.
I turned the boiler off, and re-bled all the rads, but it makes no difference.
Any advice would be appreciated....
try draining again but dont turn water to f&e tank off, then you can check if said tank empties, if not you have a blocked cold feed.
