I am replacing the entire alarm system in the house as it is a bit of a mess. I know there is a separate section for that so I won't go into that here.
I intend to use the original mains wiring which off the lighting circuit. Is it ok to have an alarm running of the lighting circuit? I can't see a problem with it in terms of safety as the control panel draws very few amps but we are having an inspection done soon so before I replace the alarm I could with knowing if this is likely to through up any problems with the inspection.
I guess technically it should be off a FSU but there is ring main any where near the alarm control panel which I guess is why it was wired of the lighting circuit.
