hi
hope sombody can help with a problem with my combi,just had a new divertor valve kit fitted to cure low dhw temp,this is now fine however if c/h is running and dhw is used it takes several mins once tap is turned off before heating fires up again it stops fan and is pretty much just turns off,no lights on front to say a problem,have changed the thermistor with no change ,it does eventually come back on but it used to be near straight away.hope some alpha guru can help.regards Neil.
