Hi all, I have an Ocean Alpha 240P combi boiler. I had my diaphagm replaced a year ago to solve a hot water problem, found I needed it from these forums so as a result I gave plumber exact details for repair, which was nice.
However, I have a new problem... again with the DHW.
When the hot tap is turned on and the CH is not currently on the boiler registers the need for hot water but does not fire up, the fan kicks in though. BUT when the CH is running and I request hot water, the boiler cuts off. HOWEVER it seems that if the heating has been on for a while the hot water does not turn off the boiler and I can get piping hot water.
I can see the diaphagm is doing its job.
Hope you can shed some light on this.
Thanks,
Martin.
Thanks,
Martin.
