Partially blocked heat ex does not affect the flow rate coming through the taps it there is 2 circuits so to speak one that goes through the boiler and transfers the heat into the water passing by to the taps.If it gets up temp then cuts off after a few mins then cycles like this it is probably heat exchanger... Sensor takes 5 mins to fit and usually shows by more rapid on and off
