Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a 2 year old Alpha cd28 that is leaking water from underneath the boiler i have had a plumber come out to look and he said that he could not see where it was leaking from does anyone have any ideas
Less sarcasm please, and lighten up.That boiler has so many unions and washered joints both on the heating side and the domestic water side.If the system pressure is remaining constant then you can eliminate the heating.Best way is to remove the front cover.drop down the controls door and watch/feel for signs of water.
alphas are prone to leaking from all sorts places get some one else in
p.s. if pressure drops then its on central heating side
if not its hot water side
