My boiler is not giving me HW or CH. Lamp A & B are flashing together. The boiler fired up for a couple of minutes this morning then it sounded like the fan wound down (like it came under load) and the flame went out. I have followed what the flow chart in the installation instructions says to do for fault finding. This is where I am lost. After saying that it is a fan or Flue fault, it gives a few voltage checks that you can make according to your symptom (lamps). For mine it says to check two volages at the PCB for the air pressure sw. One fails, saying to replace the sw. it also says to check a voltage again at the PCB for the fan, which also fails. 0v when it should be 240v. On checking back along the circuit, I cannot even get 240v at the main terminals of the PCB or the Boiler (yet I am getting 26v at my previous check from somewhere)!
What have I failed to see! HELP! Is there a cut off switch that I need to reset or something?
Thankyou for your time.
