Alpha cb28 boiler problem
4 Dec 2017
Hi all
i have a problem with my boiler alpha cb28.hot water runs fine most of the time but does occasionally run cold. The central heating after it has been on for about 1 hr it shuts down with a solid red light & yellow light flashing although the fan is still running & stays like this for about 1/4 hr then starts itself up again & the red light goes off untill the next time, which could be 1/2hr or sometimes its ok for hrs, i have drained & refilled the system,the pump is working & clean & all rads get hot. we do live in a hard water area & boiler is about 13yr old but is serviced anually.it has had a diverter valve & flow switch fitted few years ago any advice appriciated.
regards loyd
hi & thanks do you mean the low water pressure switch or the dhw flow switch as dhw flow switch has been replaced before
low water pressure switch ,it probably just needs cleaning, but your pump could be sticking, both would give you that fault
