Hello there, First time post but have found this forum very usefull in the past
I have a Alpha CB28 boiler that seems to have developed an intermittant fault.
Both LED's flash together which the manual says is a Flue or Fan fault.
I have had my multimeter on the fan supply at both the motor and board ends. The voltage readings are very irratic.... is this normal?
The fan does spin up when its asked for but occassionally after being run for a while it trips with both lights flashing. The fault resets its self if left idle and no water use.
Any suggestions how to identify if its truely a Fan on PCB fault?
