To start with I'm not an expert on plumbing or heating I freeze when anything happens.
When turning on the hot water tap the boiler fires up everything seems to work like normal, but as soon as the water gets warm/hot the pressure goes from green to 4 bar and the boiler stops, and before it stops you hear a noise like a engine has seized up.
The Central heating works.
Last week in the evening the water pressure in the area was low, at that time I did not know it was a problem in the whole neighbourhood I thought it was our boiler so I starting bleeding the radiators (I said I was not a plumber) and then added more water into the boiler with the filling loop, this did not help but as I was a bit stressed I did not fully close the tap everything seem to be ok. The next day my wife called me saying the boiler was leaking when I got home I realised my mistake I manage to stop the leak by bleeding the radiators .
But now we don't have any hot water.....
I assume some valve must have been damaged or ?
Any help would be appreciated.
All the best
All the best
