what could cause a fortic to overflow with very hot water? - it happened overnight - the ballvalve is working fine, the overflow is taking water away no problem, so there must have been a lot of water in a short space of time, the water on the hot-taps was scalding in the morning, but the cylinder stat seemed to turn the boiler on and off when needed, the lad didnt check the pump and theres no immersion on it, he drained it down and re-filled it and ran the heating and hot water (potteron envoy) and everything seemed fine and has been for the last couple of days - there was a heating engineer out to the envoy the day before but apparently all he did was change the pcb - any ideas chaps, thanks
