My Zanussi ZRB32213WA is pooling water at the bottom of the fridge compartment. So far I have:
I was considering removing the tubing from the back of the fridge to investigate, but the back panel is covered with, what seems to be, a corrugated plastic panel. Is this easy to remove?
- Left the unit turned off to defrost.
- Stuck a 30cm zip tie down the drain hole and jiggled.
- Blew air down the drain hole through some tubing.
- Put bicarb soda and vinegar down the drain hole.
- Checked the drain tray at the back to find it completely dry.
- Used a Pela pump down the drain hole and tried to aspirate.
