So as the title suggests, I have a Worcester Bosch Greenstar Junior 28i boiler and the MT10 mechanical timer has broke. The clocks ticking away but it does not fire up at selected time. I've tried changing the selected times and made sure the times between the 24hr and 12hr indicators match and still nothing.
The boiler still works when set to "ON", its just the timer settings not working.
So I need to replace the timer. I was thinking of replacing the MT10 with the DT20. But I've also been considering using a wireless thermostat.
I have read good things about the Honeywell CM927.
My question is do I even need to replace the MT10 timer at all? If I got a CM297 and wired it up to the boiler and have the existing MT10 switched to "ON", would I be able to control timer settings through the CM927?
Thanks,
Granite.
Thanks,
Granite.
