- Joined
- 22 Jan 2007
- Messages
- 8,526
- Reaction score
- 4,533
- Country
Hey All.
Will be starting work on the bedroom on my house rennovation shortly.
2 outside solid sandstone walls with old lath+plaster internal coverings at the moment.
I have 50mm Celotex insulation boards which I plan to frame the two walls and fit between them.
I know if I was going direct onto the brick, I would use 60/70mm deep battons to give a 10/20mm air gap between the back of the celotex and the stone wall.
But could I just leave the lath/plaster in place and fit celotex direct to that which would still give the origional gap behind the lath/plaster and just use 50/60mm deep battons to either have the celotex flat against plaster or 10mm gap behind?
