It came up as a DIYnot advert, I did try putting a standard fan blowing on radiator but it was too much, and cooled the radiator too fast, the old Myson fan assisted worked well.
They work best on rads running at low flow temps. Heat pump systems are the classic case. On a boiler running at 70°C the gain is pretty small.
Go for the ones with a thermostat, so they only kick in when the rad's warm. Otherwise they just blow cold air around.
Noise and trailing cables are the usual complaints. Fine as a quick fix for one cold room. The proper fix is still a bigger rad.
