Apollo 40B banging boiler
21 Feb 2005
Please help ....
My Apollo Boiler & pipework is making banging noises when the heating thermostat switches off. The pump stops and the boiler flame goes out when the stat switches. I have already changed the High/Low stat but the problem persists. I have chemically cleaned and dosed the central heating system. I also added Fernox noise silencer. The gas valve also locks out and shuts off the pilot light on occasion when the central heating stat or hot water cylinder stat switch off. The grunfos pump is under a year old and is in the high speed setting. The 3-way valve is working fine and all the rads are working ok.
I'm not sure if the boiler has a pump overrun stat or not :?:
Should I clean the system again :?:
Please help.
Regards
DIYMike
Kevplumb
:lol: thanks for the fast reply
If the pump is switching off at the same time as the boiler flames off - does this mean the stat is faulty? Should the pump continue running for a while :?:
