- Joined
- 13 Feb 2023
- Messages
- 14
- Reaction score
- 3
- Country
I have an Aqualisa Digital Pump Processor (Looks like this: https://pelhampumps.co.uk/products/...processor-combi-hp-high-pressure-434000-black)
It had a leaky shower head so I decided to buy new seals, the good news is that I've been able to remove the pump, fit the new seals and stop the leaking shower head.
But, when I was taking the pump apart I stupidly removed the inlet/outlet by unscrewing the fitting that goes into the pump instead of just pulling the compression fittings. Now when I reassemble the pump I'm getting a leaking from these fittings.
I'm aware that over tightening could be an issue so I've tried to just be finger tight, but I'm also conscious that if they aren't tight enough then I'll have a problem.
