Aquarius SDW60 eco light flashes after 10 secs
16 Apr 2009
Glasgow
This is a new fault with the machine.If you choose any programme the machine will sound as though it's going to fill but the eco light flashes after 10 seconds and the machine keeps making the filling noise.
I've noticed this problem on a few other pages but nobody seems to have a solution-not even the manual.It just says call hotpoint.When you call them you need to either be in warranty or pay a huge amount of cash for somebody to come out.
Any help would be greatly appreciated!
water in base of mc ,tip mc back with towels on the floor when its stopped pouring water out check the spray arm are not loose its a nut at the bottom of the arm ,then check salt nut is tight ,then check the small turret at the back near the bottom spray arm all this is inside of mc .try it after this if it dont work you have a leak from under the mc . 6 screws to remove base and have a look.
