Aquarius wml520 only runs on Eco cycle.
2 Dec 2015
When I try to run a normal length cycle it Cuts out during spin and that's it.
Any suggestions?
N
Can you explain more. Cuts out wot the power, does it do a wash on all programs does it spin. Empty etc
We've tried the same thing empty and it still does it. It begins the spin cycle then pauses and just stops with the indicator light highlighting that it's at the spin stage. We then have to turn the machine off and put it on the fast wash (which works ok) to get it to spin and finish.
Check the motor brushes poss worn down
Surely if it were the motor brushes the drum wouldn't turn at all?
Not always the case. Could be arking due to carbon dust or just on the limit.
