hotpoint Aquarius WML520 fault
1 Oct 2009
Hampshire
Hello all,
Hotpoint Aquarius WML520.
It gets stuck on the wash cycle, if you set the machine to do a wash, it will keep washing all night and never stop, same on all wash programmes.
Seems to work fine on rinse and spin cycles.
Is this a programmer fault or possibly a heater fault?
I have heard that if the element is bust, it doesn't heat the water, so the programme doesn't advance and loops forever?
I haven't beable to check if it's heating yet.
Anyone in the know who could point me in the right direction? Ie if this is a common fault.
Thanks in advance.
Very common for a Heater fault. Or filter blocked. Check the heater with a meter.
cool cheers mate, filters been checked apparently.
will check the heater, will just need to weigh up the cost to repair vs replace with a cheap machine.
Heater is 20 quid about 10 mins to fit. Found at the back of the drum remove rear panel.
Thats the one. Have you tried eBay.
yeah, nothing.
i will check to see if it is that and try a local spares place in town.
thanks again.
