Wondering if these electrics are enough for a new cooker I'm having delivered tomorrow? Its a Bush BEDC50W Previous owner had this so I presume its all OK? Help! Otherwise need to find an electrician. Thanks
Oh gosh OK. I just assumed that it would b OK as I've been using my 2 plate electric hotplate on this connection. I'll get it checked. Thanks for the reply.
hard wire means the electrician will have to fix a length off cable to the cooker and bolt/ screw inside the box via the hole at the bottom under the switch marked "cooker"
