Recently my Ariston 27MFFI has started to supply heating to the radiators when not required, even when the programmer is completely removed!
The boiler periodically fires and heats up the water in the heating outlet pipe to a very high temperature. Some of this heat is reaching the radiators (even though the routing valves have not been opened by the controller). The boiler does not go out on overheat, the flame just shuts down and refires again later. Meanwhile the circulation pumps runs continuously. The only way I can stop this happening is to turn the boiler off completely. If heating is requested it works normally as does hot water. Can anyone please suggest why this might be happening and how to fix it
