hi,
I have an ariston combi a boiler, it's probably 10 to 12 years old, and when we run the hot tap in the bath it goes hot and cold, and you can hear the boiler firing up and down when it does this.
Last winter we had the domestic hot water heat exchange replaced and that seemed to cure the problems. However it seems to have come back, which is disappointing.
We live in a hard water area, and the heat exchanger seemed pretty blocked when it was removed last time. However I can believe it's become blocked in such a short space of time.
The ch is effectively new installed 8 years ago and then extended 2 years later. So I can't imagine there is to much crud floating around the system. We also have a fernox tf1 installed, which is always very clean.
Is there anything else likely to cause this behaviour.? Or do I suck up for another heat exchanger, or try and clean the existing one, with after fernox descaler? Or God forbid, new boiler as 10-12 years is the life of a combi?
Thanks for any advice.
Adrian
Adrian
