Ariston MicroGenus 24 HE MFFI - Error A03
28 Mar 2014
Bristol
Heating runs for approximately 5 minutes then errors. On reset, cycle repeats. Error code indicates that returning pump temp is above 103 Degrees.
I replaced the Overheating Thermostat (Ariston Part #996065) but issue persists.
I then switched off the heating and the hot water will run for 5 minutes without error; suggesting that the expansion vessel is okay.
Does this suggest that the pump is degraded / broken?
(I'm no boiler engineer - so the above assumptions I've made might well be wrong!)
It could be a number of things but your going to need a boiler engineer to look at it, does sound like a circulating problem are could be diverter valve stuck in hot water position are faulty ntc! All of which can be tested to see if there working before being replaced
Ian, I read the topic you linked to and got a distinct feeling of déjà vu.
