Ive been using some from local wholesaler, but the earth tag is just poor, Im sure there are better brands on the market.. just would lilke some recommendations.
I always use Pirelli glands from 'Newey and eyre', they cost a bit more as you get everything you need in a packet (shroud,earth tag, adapter for 20mm and a locknut)
Im not bothered if they come as a kit, Im just not too enthusiastic about the earth connection on them, I like to use a 10mm or 16mm earth to them depending on what is for, but regardless of the gland size they allways seem a bit thin with a tiny hole.. does every body else drill through the cu and tag and bolt right through, unless IP rated?
