Attaching ply to concrete floor for rubber tiles
1 Jul 2012
England
I have a small utility room and plan to tile with rubber floor tiles (the knobbly ones).
The floor is concrete but is not beautifully smooth, as has had 1960s lino tiles stuck to it. Was thinking of using 6mm marine ply to level it and then the rubber tiles glued to that.
If that's a sensible route, how do I attach the ply to the concrete floor? and should I cover the whole floor and put the appliances on top (washer and dryer)?
Simon
I was wondering that too. Would I need to get the old vinyl up first (They're very fixed).
Not sure, but probably.
Use a spade if removing the tiles. Be aware that old tiles could have small amounts of asbestos.
I hope someone can chip in about using leveler over existing tiles.
If the tiles are properly tightly fitted and going nowhere, you can screed over them with something like F-Ball 1200 or Arditex Ardit NA self levelling compound. You need to consider that those tiles MAY have a high Asbestos content (most are fairly benign if they are Asbestos tiles but some you have to be more careful of.) If they do not look damaged and are well fixed and not lifting, screeding with the appropriate screed as mentioned is a viable option.
If the tiles do indeed contain asbestos (some old vinyl tiles do) I personally feel it's probably best to remove them (heat gun and peel them up whole) so that a future occupant of the house doesn't accidentally release it by hitting the floor with a grinder etc
Never been a fan of sealing it in, booby trap for the next poor sucker
