hi
My Power supply has packed up.It is made by HEC and the model is HEC300AR-PTF and it is 300watt the dimension are approx 140x85x150
connections are 2x dvdwr-floppy-maxtor hard drive ATA-motherboard has 2 connections.I have tried to look for the exact replacement but have failed.I am novice on the hardware and will be grateful for help from the knowledgeable ones to advise me on the exact replacement like to like so i cannot get confused. Also advise if i can upgrade to400 watt .if further info is required please advise.thanking in advance
ih
