Hi all,
I have 3 keyed-alike avocet ABS cylinders for my garage - one for the normal door and half-cylinders for the up-and-overs. The problem I have is that the ones in the up-and-overs struggle to unlock with the key when it's frosty out. I assume the problem is likely that the magnet does not have enough pull to shift that particular pin when it's a bit frosty, where as all the others are mechanical and so free up easily as the key is inserted.
Any locksmiths or pickers on here that might have a suggestion to disable that magnetic pin, or other solution?
