I swapped the front and back door euro cylinders a couple of days ago. Replaced them with avocet abs ones. Pretty straightforward. Backdoor works fine. Front door was okay too.
This evening, I was showing SWMBO about using the locks. Somehow, I put the key in, pulled the handle up to engage multipoint locks, turned the key to lock it and it became stuck. There was no way I was able to open the door.
The key wouldnt turn. With a bit of force, I was able to pull the door handle down so I could at least open the door.
The key still doesn't turn. I've removed the retaining screw and the door handles but I can't remove the cylinder. The key now rotates about 15* in either direction. i've tried a second key on the other side of the lock but no joy.
I'm at a loss and short of calling a locksmith I'm not sure what I should do next.
